hi guys im looking for a really small but powerfull amp for use with my ulrta portable setup.
my netbook and herc mp3 e2 are the same length and about the same width approx 12" x 8"
so, im looking for an amp thats about the same size so i can nip down to swan and get a custom case made. help needed please.
geposted Mon 14 Feb 11 @ 3:56 pm
How about the Vestax VDA-1000MK2.
http://www.vestax.com/v/products/detail.php?cate_id=82&parent_id=9
Here are the specs:
POWER AMP SECTION Bridged 8ohm = 1000W 16 ohm = 520 W
Power EIAJ, both channels drivin
4 ohm= 2× 500W
8 ohm= 2× 270W
Power continuous, both channels driven
4 ohm= 2× 390W(1KHz, 0.5% THD)
8 ohm= 2× 240W(1KHz, 1% THD)
DIMENSIONS 89(W)×195(H)×320(D)mm
Weight:3.0kg
It has a USB digital sound input as well. It is very cool. I'd love to have one.
-DGee
Here are the specs:
4 ohm= 2× 500W
8 ohm= 2× 270W
Weight:3.0kg
-DGee
geposted Mon 14 Feb 11 @ 8:16 pm
Hi Blu
How about! Stuff the amp and go for a pair of powered speakers.They must be available on the good old E of Bay. Keeps the weight down and reduces your rack size. Take a line level signal direct to the speakers and no fuss.
Daz
Daz
geposted Wed 16 Feb 11 @ 1:59 pm
Vestax amp looks good but would need venting in the case.
Unless you already have speakers you want to keep using then I'd go for powered speakers. If one fails you can finish gig on just the other. If amp fails your stuffed.
geposted Sat 19 Feb 11 @ 1:26 pm
Hej Babe, What about a Cambridge Amp... They are great and pretty underrated too.
Richer Sounds in Brighton have them for about £70. You could probably find them cheaper even than thatl.
XXXSeanaXXX
PS but i did like the sound ov those Powered Speakers (if they're any good) as they will keep all your bits and the weight down to a minimum...
XXXSeanaXXX
geposted Sat 19 Feb 11 @ 2:36 pm
Try getting active speakers such as Mackie 450v2's
geposted Sat 19 Feb 11 @ 7:21 pm
