Ok, against my better judgement and just because the love of the program (I have been having problems with VDJ LE) I am wanting 2 upgrade to the pro version of VDJ using my upgrade discount.(Sorry for the rant). If I do upgrade will I get VDJ Pro Full or is it VDJ Pro Basic that I am getting?
geposted Tue 15 Feb 11 @ 10:30 pm
What I can tell you, is that you will receive a deep discount on an UpGrade, go to the site and check it out for yourself, Onething is You will have everything in full effect with no limitations at all, I wound say ......Go For it....Do It Well.....
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 15 Feb 11 @ 11:34 pm
Well my only concern is that I saw that there is 2 different versions of Pro, that is Pro Full & Pro Basic. I just want 2 make sure I'm getting the pro full version.
geposted Tue 15 Feb 11 @ 11:38 pm
You decide that when you visit the site and make the Upgrade decision then, I still would say to go for it... the Full Pro is the way to Gooooo.....and you only need to do it once...the benefits will continue for you, with endless downloads of skins, effects, ect, ect, ect...
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 15 Feb 11 @ 11:48 pm
When I hit upgrade it just gives me one price, it doesnt give me an option to choose which version.
geposted Tue 15 Feb 11 @ 11:56 pm
You will get the current version 7.2, I'm not sure, but did it give you a choice... to pick from..?
geposted Wed 16 Feb 11 @ 12:00 am
Did you Enter the keycode of your current product first..?
geposted Wed 16 Feb 11 @ 12:05 am
It has my keycode automatically that is assigned with my user ID. But considering the price I am assuming that it is the Pro Full Version. considering my upgrade price is more than what the basic pro price is at regular price. But significantly cheaper than the Pro Full
geposted Wed 16 Feb 11 @ 12:11 am
Ok, then you're at the decision stage of the process....any thoughts..?
geposted Wed 16 Feb 11 @ 12:19 am
