I have VDJ 7 and Numark Mixtrack (not pro) I was wondering if it was possible to set each decks stutter button to instead of stuttering the song at say cue 1 that it will beable to switch from say deck 1 to deck 3 and back if pushed again. This way I can control 4 decks with the push of stutter and mix all 4 tracks per-say.
Or if there is an easier way of controlling 4 decks with only a 2 deck midi controller like my'n help would be great ^_^
Best,
Dylan
Best,
Dylan
geposted Wed 16 Feb 11 @ 7:41 pm
device_side left ? deck 1 leftdeck? deck 3 select & deck 3 leftdeck : deck 1 select & deck 1 leftdeck : deck 2 rightdeck ? deck 4 select & deck 4 rightdeck : deck 2 select & deck 2 rightdeck
geposted Thu 17 Feb 11 @ 1:25 am
Sweet, so how will I apply this into VDJ? and is it the stutter butter that I will push or what seems like a slide?
geposted Thu 17 Feb 11 @ 8:12 am
bump
geposted Sun 03 Apr 11 @ 11:20 pm
Check the manual for further instructions https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20User%20Guide.pdf (page 44)
geposted Mon 04 Apr 11 @ 4:41 am
