when i download the mapping for thre Hercules rmx 4 deck i cannot load it, can someone help please?
geposted Wed 16 Feb 11 @ 10:27 pm
if its a zip file you unzip it to any folder and then put the xml mapper file in my documents-->virtual dj--> mappers
geposted Wed 16 Feb 11 @ 10:32 pm
thanyou so much, is there any info you can share about the sound setup and switch between decks 1'2'3 & 4. anything would help thank you.
geposted Wed 16 Feb 11 @ 10:47 pm
since the rmx only has 2 out, you would use the same output settings you would with 2 deck (ch 1-2 master and ch 3-4 headphones)
for switching between decks map a button to the following
device_side left ? deck 1 select ? deck 3 select & deck 3 leftdeck : deck 1 select & deck 1 leftdeck : deck 2 select ? deck 4 select & deck 4 leftdeck : deck 2 select & deck 2 leftdeck
geposted Thu 17 Feb 11 @ 12:30 am
