Hallo!
Have anybody a mapping for Reloop Contour (Interface Edition)? I use it with Traktor, but i am NOT happy, want to try it with VDJ. When good, i buy also this great soft!
Thx!!!
Thx!!!
geposted Thu 17 Feb 11 @ 1:34 pm
info from Reloop:
"VDJ has the Contour for Mapping - please contact their support to find out when it will be applied."
Also, my question is, when will be midi mapper for Reloop Contour integrated in VDJ????
thx for info!!
thx for info!!
geposted Wed 16 Mar 11 @ 5:51 am
they said vdj support should help us :D
geposted Tue 31 May 11 @ 10:58 am
It is natively supported in the latest VirtualDJ v7.0.4 Pro: https://virtualdj.com/buy/
You can try it out before purchasing for 10 minutes at a time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
NOTE: After 10 minutes, Home FREE will revert back to mouse and keyboard control only until you next restart the software.
NOTE: Unfortunately the Reloop Contour does not support standard MIDI SysEx ID for automatic identification. This means that it will not work with Windows XP, which does not support any of the other identification methods used (VID/PID = Windows 7/Vista only, or MIDI driver name = MacOS)
If you are using Windows XP, you will need to upgrade to Windows 7 if you wish to use this controller with VirtualDJ.
geposted Tue 31 May 11 @ 11:19 am
