Is there a way to reset Timecode Configuration to default settings without backing up mappers/config and re-installing? Ive messed with gain, lead time, pitch so much I want to be sure its 100% default. Also when using the registry fix tool, is it necessary to apply fixes after each software upgrade? Thanks
geposted Fri 18 Feb 11 @ 2:15 pm
