Hey,
Is there manual BPM option in VDJ? When I use the pitch control, it always jumps from like 137.4, straight to 138 or more. I want to set it myself to either 137.5, or 137.6 and so on. Is this possible? If so, how?
Thanks.
Thanks.
geposted Fri 18 Feb 11 @ 3:26 pm
Hej babe...
Right click on the track and select "file options" and then select "Manual BPM"
Hope that helps some.
XXXSeanaXXX
XXXSeanaXXX
geposted Sat 19 Feb 11 @ 2:41 pm
Yep, helped a lot - found it. Thanks, Seana.
geposted Sun 20 Feb 11 @ 1:41 am
or remap your pitch controls to increase and decrease at the specified increment you want.
i use the pitch bend buttons on my herc to increse/decrease at 0.01
it is different depending on what machine you use, but my netbook is set to
pitch +/- 0.07%
and i think my laptop is
pitch +/- 0.073%
pitch +/- 0.07%
pitch +/- 0.073%
geposted Tue 22 Feb 11 @ 3:30 pm
When I press or tap my pitch button it speeds up but as soon as I take my finger off the button it goes back to the original pitch it was at. Can someone help me with that? As a matter fact I dont use the pitch like that because I dont really understand how to set it. Can someone explain? Thanks.
Andre
Andre
geposted Fri 25 Feb 11 @ 10:24 pm
your using th pitch bend button. the pitch bend is used for many reasons, one is fine tuning your beat matching. speeding up the pitch with the pith bend will essentially fast forward the the track by milliseconds.
say your tracks were a half beat out, you can speed up or slow down one track by a fraction, to get the beats lined up. when you leave go again it stays in sync both by pitch and by bpm.
what you need to do is use your "pitch control", not your pitch bend.the pitch controll can be mapped to suit your own taste. so you cound map it to increase by 0.1 bpm or by 1.0 bpm etc.. when you activate the knob or slider.
i personally have the pitch "control" as standard
i use this to get as close as possible to the correct bpm match, then i have my pitch bend "re-mapped" to increase/decrease pitch by 0.07%or 0.1 bpm each time i press the button.
personally i dont like using the pitch bend hence why i remapped my controller to finetune how i want it to.
geposted Mon 28 Feb 11 @ 12:11 pm
Please can someone help me on how to create shortcut
geposted Sat 18 Apr 15 @ 5:36 pm
