Is it possible to have both Time Code and Line In modes available for use at the same time?
For instance, I have my two decks, with TimeCodes on, but if I want to switch to line-in mode to play a normal vinyl - then back again? I know there used to be a "pass-through" mode which seemingly got scrapped at some point?
The thought process is this:
Advanced Config:-
Timecode 1 | Maya 44 Asio | In 1 & 2
Timecode 2 | Maya 44 Asio | In 3 & 4
Line In 1 | Maya 44 Asio | In 1 & 2
Line In 2 | Maya 44 Asio | In 3 & 4
And then have buttons on the skin to enable/disable/switch between the two?
Thought I'd ask before I spend a week trying to figure it out, only to find it's not possible!
Edit: Went looking in the mappers and found "timecode_bypass" would this work as I imagine? I.E. Showing the wavform as it comes in?
Advanced Config:-
geposted Fri 18 Feb 11 @ 3:43 pm
Yup that'll work.
Huey
Huey
geposted Fri 18 Feb 11 @ 5:28 pm
Cheers Huey - just give it a blast, flawless. Top Stuff! :D
geposted Fri 18 Feb 11 @ 7:38 pm
Want to be able to switch between phono and line in from time to time so that I can switch between timecode and vinyl. What are the best cables to use to hook this up?
Been looking at the traktor multicore cables which seem like the most expensive cables that will suit this purpose.
Any ideas where I can buy a cable (or combo of cables) that will do a similar job for less cost?
Cheers
Cheers
geposted Fri 04 Mar 11 @ 5:29 am
Radio Shack............any RCA's will do.
Good Luck
Huey
Good Luck
Huey
geposted Fri 04 Mar 11 @ 10:58 am
