Hi, I want to know what is the minimum HW to use the TCV like a vynil for scratch and beat jungling without latency?
I use a Portable Celeron 1,50 750MB RAM with XP home vdj 2.06 and maya 44 usb, but when I scratch there is some latency, why? my HW is no good?
2nd question:
Can I use the TCV for a mix and the crossfader of VDJ excluding the TCV and using the normal VDJ for the next mixage? How?
Thanks,
Roberto.
2nd question:
Thanks,
Roberto.
geposted Sun 24 Jul 05 @ 12:50 am
Kinda old version. Are you a legit user? Or using crack. If so, I can't help you there.
Numerous people use TCV's with the full version flawlessly.
geposted Sun 24 Jul 05 @ 9:25 am
Try Buying VirtualDJ and install the last version. You may resolve your problem.
geposted Sun 24 Jul 05 @ 1:48 pm
ok, but my portable pc is ok for a true scratch like I want?
Thanks,
Roberto.
Thanks,
Roberto.
geposted Sun 24 Jul 05 @ 2:46 pm
Yes it's ok with your spec.
geposted Sun 24 Jul 05 @ 4:19 pm
