Can vdj 7 be set up to allow multiple users? For example: my business partner and I would both like to come over to vdj. But, we would like to set up our computers so that if his is down and needs mine (as I work every other weekend), he can plug in his external hard drive and go with it. Would vdj give him all of his presetup folders etc? Thanks in advance for the help.
geposted Sat 19 Feb 11 @ 11:13 am
It should. The preset folders are stored on the hard drive.
geposted Thu 21 Apr 11 @ 10:47 pm
how many computers does a pro license allow you to install it?
geposted Fri 22 Apr 11 @ 3:41 pm
The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
geposted Fri 22 Apr 11 @ 4:43 pm
So i bought virtual dj pro postal delivery. I installed it in my toshiba and mac. If i want to install in my dell i have to uninstall in my toshiba
Correct. CAN i use the toshiba, mac and dell?
What happen if all of them are in use at the same time?
geposted Fri 03 Jun 11 @ 5:55 pm
You can download the install file for the software again (If needed) from the Download Center: https://virtualdj.com/download/updates.html
geposted Sat 04 Jun 11 @ 12:39 pm
