Hi all,
I have i difficult time to create smooth bridges when playing classic funk music from the 60-70th. There are so many different beats so it is almost impossible to beat match even when having the same bpm. How do you do it when playing funk? Or do I have to rely on using brakes etc.
Thankful for your advice.
geposted Sat 19 Feb 11 @ 4:59 pm
I just match the BPMs
geposted Thu 10 Mar 11 @ 10:50 pm
breaks and effects help a lot when mixing funk. it is very hard. u might also try to mix on the cymbal or hand clap as opposed to the bass drum.
That works for me sometimes on hip hop and rap.
geposted Fri 11 Mar 11 @ 3:24 pm
You Have A Count Of 1234 4x Before The Rhythm Change Of Something Is Add Or Taking Out The Track. Its ZE Listing To Dr Dre Chronic Songs It Will Give You That Old School Funk With The New Sound.
geposted Mon 21 Mar 11 @ 4:26 pm
