This is not a real effect but it intends to help you understand the video memory use
http://www.virtualdj.com/addons/12763/FPS.html
Please report us your results in order to help us improve VirtualDJ
geposted Sun 20 Feb 11 @ 12:19 pm
nice! will come handy when i get my Alien...imao
geposted Sun 20 Feb 11 @ 11:29 pm
I installed it but its empty in the Video effect page (No description or activate button). How can i update my DirectX if i need to? Where can i see my current DirectX status? (Win7 64bit)
geposted Mon 21 Feb 11 @ 10:37 am
I have just uploaded a new version with an older DirectX SDK. Can you try again.
geposted Mon 21 Feb 11 @ 12:43 pm
works now...
![](/image/8222/55526/FPSscreen.png)
Can these infos be saved in a file?
geposted Mon 21 Feb 11 @ 3:09 pm
You can record it with VDJ or use the following plugin if you only want the data at a special time:
http://www.virtualdj.com/addons/2417/Screenshot_v1_0.html
Can you tell me if the OpenGL values change when you resize the video window or load a video? Other ones?
geposted Tue 22 Feb 11 @ 12:47 pm
When i resize the window, or when i load another video, the only thing is changing is the AvailableTextureMemory.
OpenGL info doesnt show up if i send the video to a secondary monitor, but i guess you already know this :p
geposted Tue 22 Feb 11 @ 3:29 pm
Can you just tell me which value you have in my Registry Tool for the option "VideoMemFree" ?
geposted Tue 22 Feb 11 @ 4:06 pm
VideoMemFree=497
geposted Tue 22 Feb 11 @ 6:27 pm
I dont usually have problems running videos but heres a screen shot,
![](/image/87558/55867/fps1.bmp)
VideoMemFree=234
Is there any thing that I should be looking for or change??
Hope that helps
Huey
VideoMemFree=234
Hope that helps
Huey
geposted Fri 25 Feb 11 @ 7:05 pm
I have just found the bug and I will upload a new version in 4-5 hours. Thank you.
geposted Sun 27 Feb 11 @ 10:22 am
Version 2.1 is now available. The plugin can now be used with the external video output
geposted Sun 27 Feb 11 @ 1:10 pm
Ok. it works now.
I try to understand how does the video loading works..
1. It seems that when you load a video the AvailableTexture Memory remains the same (or better almost the same, has a small leak, even if i have AutoCue disabled. Seems it loads just a few frames) and then it decreases when you press PLAY. It needs a few seconds to reach to minimum point. Does this means that the video is not loaded entirely into memory?
2. Although i have unloaded both decks, the AvailableTextureMemory is less than the VideoTextureFree. Souldnt they be the same? Or does the skin has to do something with it?
![](/image/5102/56060/FPSscreen2.png)
geposted Sun 27 Feb 11 @ 3:47 pm
Yes that's the problem to develop such plugins. It help us as developpers but then users want to understand data ;-)
What you are trying to describe and understand is normal but do not loose too much time on that.
All I can say (ie allow) is some data should change if:
- you resize the video window
- load/unload a video
- play a video
Something I would like to investigate with you is the second line in OpenGL because the OpenGL code (part 2) is not recognized whereas it should work on your video card. I will send you a PM tomorrow.
- play a video
geposted Sun 27 Feb 11 @ 4:58 pm
Plugin updated to add RAM detection
geposted Sat 23 Apr 11 @ 3:19 pm
![](/image/59160/61521/virtual dj.png)
geposted Tue 10 May 11 @ 4:54 pm
just looking for help with this I can't seem to get a answer from nobody in the general fourm..
My lappy is freezing and the program goes into not responding any help would be great..
geposted Wed 11 May 11 @ 12:19 am
I have just uploaded a mac version of the plugin
Can you test and report before I go on adding code.
geposted Wed 25 May 11 @ 2:48 pm
its too bad you couldnt have had it save the information as a text file ;-)
would have made my life easier .. :-)
geposted Wed 22 Jun 11 @ 11:34 am
OK heres a shot with the memory at its lowest point.. (before I start playing videos etc)..
![](/image/76360/65162/vdj 1.jpg)
and heres a shot after playing a video on the left side, load one on the right side.. let video 1 finish playing and start video on right side..
then load video on the left side..
If I keep doing this.. let the video completely play all the way thru.. very quickly I will max out available memory..
(some memory is reset when I new video is loaded.. but not all of it)..
![](/image/49493/65163/vdj 2.jpg)
geposted Wed 22 Jun 11 @ 11:40 am
