Before christmas I bought a Hercules DJ Mp3 e2!!! to be fair its a good little piece of kit and looks up to the job :)
The only problem is I can only listen to either Track A on its own or Track B!!! so basically it wont play two tracks at
through the headphones which is really annoying :( Someone help!!!!!
geposted Sun 20 Feb 11 @ 2:40 pm
Try turning the headphone mix knob. It should be at the top of the skin not sure though.
Hope that helps
Huey
Hope that helps
Huey
geposted Sun 20 Feb 11 @ 3:14 pm
The MP3e2 does not have a built-in DJ sound card.
To be able to pre-listen to music using headphones, you will either need two sound cards or a sound card with multiple outputs, such as a 5.1 surround sound card or preferably a dedicated DJ sound card (E.g: Numark DJIO or Native Instruments Audio 2 DJ.)
With a laptop, you can add a basic USB sound card that will provide you with the additional output that you need.
Alternatively, you can use a single sound card and the mono split option in VirtualDJ's sound setup, however this will only give you MONO sound. You will need a splitter cable to split the left/right channels - Please search Google for: 3.5 jack splitter to mono
Once you have suitable sound card(s), you will then need to go into VirtualDJ CONFIG -> Sound Settings and choose Outputs: Headphones and select the appropriate sound card(s).
geposted Sun 20 Feb 11 @ 3:15 pm
