Forum: Old versions
Topic: SHOUT cast Stream URL
I have just bought Virtual DJ Pro to use for broadcasting. Having the Stream URL displayed as https://virtualdj.com/ is not acceptable. I have seen various registry hacks etc, none of which work.
I require an answer from Virtual DJ staff or I shall consider this software not fit for purpose and require a refund.
Regards
geposted Sun 20 Feb 11 @ 8:38 pm
The stream URL can not be changed, so your software does perform as intended.
You could have seen this by using the FREE Home Edition before making your purchase.
VirtualDJ Home FREE allows VirtualDJ Pro features to be tried out for 10 minutes at a time as a trial of the full VirtualDJ Pro, including broadcasting.
This is more than enough time to do a test broadcast and you can restart the software as many times as necessary to obtain a further 10 minutes.
Will there ever be the option to change this please?
