Topic: Compatible Songs List on VDJ 5
Hi,
So I have VDJ 5 and have added a number of Filter Folders, that all work fine.
The problem is that if I try to add the code which I read about to get the compatible songs list (bpmdiff<=4 and keydiff=2) it does not allow me to do it says there is a "Syntax Error".
Does VDJ 5 not allow the "bpmdiff" and "keydiff" codes?
Thanks for the Help :P
geposted Mon 21 Feb 11 @ 10:36 am
These items were added in a later version of the software. VirtualDJ v5 does not support them.
Please register your serial number on the page https://virtualdj.com/users/edit.html and then update to the latest VirtualDJ v7.0.2: https://virtualdj.com/download/updates.html - There have been many changes and improvements to the software since v5, including the above.
If you have not purchased the software, then please do so by going to https://virtualdj.com/buy/
Or download Home FREE from https://virtualdj.com/download/free.html - This is free to use for non-commercial use only (It cannot be used at DJ gigs where you are being paid.)
i downloaded the free version which is Virtual DJ Home and i want to download effects , i have to buy like Virtual DJ broadcaster or Pro basic or Pro full to download them or can i just buy a membership and download them ?
