Hi all,
I have a problem with changing tracks with my vms4 & vdj 7, previously I held down shift & used the sampler number to scroll up & down my tracks, once I found the track I wanted I held down & pressed the knob down & the track was transfered to the deck but this is not working now.
any suggestions what i am doing wrong.
Cheers
Graham
Cheers
Graham
geposted Mon 21 Feb 11 @ 1:03 pm
I have also notice that loop buttons no longer work either, really bizarre !!!
geposted Mon 21 Feb 11 @ 1:18 pm
i downloaded the free version which is Virtual DJ Home and i want to download effects , i have to buy like Virtual DJ broadcaster or Pro basic or Pro full to download them or can i just buy a membership and download them ?
-sorry but i need help lols.
geposted Mon 21 Feb 11 @ 1:29 pm
Sounds like you've messed the mappings up. Easiest way is on the info tab choose factory reset - if you don't have that option then in the mapper tab set/check the following are as below:
FOLDER_SELECT to be browser_window "folders" & browser_scroll
SONG_SELECT to be browser_window "songs" & browser_scroll
Hope this helps
Hope this helps
geposted Mon 21 Feb 11 @ 2:56 pm
Hi.. I tried both but still not working, it was working fine over the weekend, when I set it back to the factory settings the looping & the song selection do not work.
I can scroll thru the folders & songs but just cant select the songs.
I have checked the mappings but they appear to be ok.
Cheers
Graham
Cheers
Graham
geposted Tue 22 Feb 11 @ 2:47 am
