Okay here is the situation. I am using my HP IQ816 touchscreen and when ever I install anything newer then the 6.0.5 version of VDJ. two things happen.
( 1 ) the not so bad... When I have my finger on the deck holding the song in place, the song will automatically start playing after a few seconds even though my finger has not moved or been taken off. Now the software will work well for a bit and then out of no where this starts happeneing.
Now number ( 2 ) The really bad thing.
After a while of playing, if I touch the screen and use the deck to cue up a spot in a song ( forward or backwards ) suddenly a crash guard screen appears. Asking me to either shut it down or try to recover. Now again this just suddenly happens after I play for a while.
Now the above stuff is not a 1 time thing. The deck playing on its own will always do it, but if I reboot, it again takes some time before it starts playing on its own again. But the crashing thing. As soon as it happens the first time. If I reboot or not, it will happen everytime after I touch the screen and move the wheel to cue a song.
Now the crashing things does not happen if I use the wheels on my console to cue the song. And the music will not start on it's own if I am not touching the screen.
I have had this problem ever since there went past version 6.0.5 of VDJ. I have to use an older copy ( 6.0.5 ) and everything work great.
Thanks
Kory
Thanks
Kory
geposted Mon 21 Feb 11 @ 8:43 pm
I dont think that it has to do with VirtualdJ since i run a Touchscreen with ver 7 with no issues.
About your first issue, i think somehow you have to disable the action that your touchscreen does after holding your finger to a position for a while. Mine does a rightclick, but i disabled as well.
About the crash, post here the contents of the Crashreport.txt file (you can find it in MyDocuments/VirtualdJ folder) and your hardware specs to check.
Thank you.
Thank you.
geposted Tue 22 Feb 11 @ 7:56 am
