i need a way to mix video clips and audio songs together
when i put an audio song the video screen will display an image i will put.
this way when i play in a club the crowd wont see a blank screan when i put audio song. they will see a picture of my project name or something like that.
please help me. i looked all over the net and nothing usefull came up.
thanks an advance.
thanks an advance.
geposted Mon 21 Feb 11 @ 11:07 pm
Clipbank is usually the most effective way to do what you are asking, either that or slideshow, maybe sonique?
What you need to do is go into your configuration settings and select the video tab. on this screen you will se a checkbox labled "use this plugin for audio only files" with a dropdown box next to it. Select the plug in you want to use from the list a check the box. Now whenever you play an audio only file this plugin will be activated.
I personally use clipbank as my audio only plugin and play a video clip with the clubs ads and promos on it.
geposted Tue 22 Feb 11 @ 12:35 am
thank you so much.. i will try it right away
geposted Tue 22 Feb 11 @ 1:31 pm
