Hello All. Just a real quick question: when I scan for the BPM of a track does vdj write that to the ID3 tag or just to vdj's database. Thanks in advance for the help.
geposted Tue 22 Feb 11 @ 1:19 am
This information is stored in VirtualDJ's database only.
However, if you right-click on a song and choose File Infos, then you can write tags back to the file by clicking on the [>] button below the appropriate field.
NOTE: Batch or automatic writing of ID3 tags is not currently possible.
NOTE: You should backup your database on a regular basis if the information contained in it is important to you. If using external drives, you should also backup the database found at the root of each drive. Also, please ensure that you backup your entire music collection.
geposted Tue 22 Feb 11 @ 6:32 am
Ok. Thank you so much for the information.
geposted Tue 22 Feb 11 @ 9:38 am
