help pls
i downloaded it today but the .............
i cant start the app because of the fu***** error message
~>Invalid skin file (error line 0 in the xml)" -
geposted Tue 22 Feb 11 @ 5:08 am
Hi There,
Try removing and reinstalling the software.
I had this problem before and doing this resolved the issue.
Si
Si
geposted Tue 22 Feb 11 @ 5:10 am
The most common cause of this error is installing the software while logged in as one user (E.g: Fred) and then trying to run it as a different user (E.g: Joe.)
The other user is missing the My Documents\VirtualDJ folder. The program will not run without this.
To resolve, please either:
(1) Install the software as the user you will be running it as.
(2) Manually copy the My Documents\VirtualDJ folder across to the other user.
Another cause is installing the software without administrator privileges under Vista or Windows 7. Right-click on the VirtualDJ installation file and choose Run as administrator. Also, we would recommend turning off UAC in Windows Vista and 7 (Search Google for: disable uac )
geposted Tue 22 Feb 11 @ 6:35 am
[Please don't make a copy of an entire post without even adding anything to it. If you need to quote something, please copy the relevant line(s) only (Not the entire message) and add your own comments/reply directly below it.]
geposted Wed 23 Feb 11 @ 3:28 am
whre i can put the copy
geposted Wed 23 Feb 11 @ 3:33 am
You will need to copy the entire My Documents\VirtualDJ folder to the other user. Copy it to the same location (My Documents) or preferably just re-install the software while logged in as the user who you will be running it as.
[Please note that we have changed your name to luck17 because the original was offensive.]
geposted Wed 23 Feb 11 @ 9:03 am
