The title says it all. I have searched the net for one and numark has no info about them even being made for this unit. Kind of sucks having 2 carry my mixtrack to gigs in a duffle bag. U know it can bump something when I'm walking and all that. So any help is appreciated.
geposted Tue 22 Feb 11 @ 5:37 pm
http://www.alibaba.com/product-gs/333717312/DJ_Control_Cases_for_Numark_MixTrack.html
You can find anything on google!
AC
AC
geposted Tue 22 Feb 11 @ 6:41 pm
yeah but that site requires you to buy 10 at a time.
Here is what I use, not purpose built but works pretty well. A little extra foam from the fabric store to make a custom fit and you can carry the mixtrack, some cables and a few other accessories safely.
http://www.csnstores.com/asp/show_detail.asp?sku=TZ1079
geposted Tue 22 Feb 11 @ 6:49 pm
Thx, and yeah I googled it the other day and that site where u have 2 buy 10 of them is all that came up for me. But is there any extra room 2 package in some mics in this case with it or is the mixtrack all that will fit in? Just curious but it looks like what I'm gonna go with.
geposted Tue 22 Feb 11 @ 8:37 pm
Im sure if your in the US, you can contact a guitarcenter and they would be happy to order if for you
geposted Tue 22 Feb 11 @ 9:12 pm
I use swanflight in the uk as they will make any size case up for you and are really cheap, plus really good quality.
http://www.swanflight.com/
geposted Wed 23 Feb 11 @ 3:59 am
Ian was on the up & up! Awesome link bro!
http://www.swanflight.com/dj-flightcases/dj-controller-flightcases/numark-mixtrack-pro-flightcase.html <<<mixtrack pro link
regards
AC
regards
AC
geposted Wed 23 Feb 11 @ 8:18 pm
I wonder if I can order that and what it would cost me to get that here in the US
geposted Thu 24 Feb 11 @ 12:29 am
Never mind my friend. I just tried the check out to see what the final price would be and the shipping is more than the case. Add in the conversion rate and it was almost $400.
Sorry dude
Sorry dude
geposted Thu 24 Feb 11 @ 12:35 am
I would take the dimensions they have on the site and see if you can get it made over there, cos that Shipping is a bank braker
Internal dimensions 477mm(L) x 307mm(W) x 64mm(H) including 60mm at rear
Approx external dimensions 520mm(L) x 360mm(W) x 150mm(H)
hope this helps.
hope this helps.
geposted Thu 24 Feb 11 @ 2:26 am
If you live in the states odyssey is your choice..this case will fit the mixtrack..
http://www.odysseygear.com/odyssey-products/fzgstks4/Traktor-Kontrol-S4-American-Audio-VMS4-Flight-Zone-Glide-Style-ATA-DJ-MIDI-Digital-Controller-Case.html
geposted Thu 24 Feb 11 @ 7:44 am
Has anybody been looking for a flightcase for the Mixtrack Pro II yet? I'm not sure this will work due mainly to the Pro II's overall smaller size in general. I'm concerned it'll be tossed around inside the case. I've never owned one of these cases before though, so I'm not 100% how 'snug' or 'loose' they're supposed to be once closed. My impression is loose is bad. Any help/links/suggestions would be welcomed.
+ Mixtrack Pro: Dimensions (WxDxH): 18.75" x 11.5" x 2.5"
Weight: 1.45 lbs
+ Mixtrack Pro II: Dimensions (WxDxH) 18.3" x 10.4" 2.0"
Weight: 4.7 lbs
Weight: 1.45 lbs
Weight: 4.7 lbs
geposted Fri 15 Mar 13 @ 11:43 pm
bump!
geposted Sun 17 Mar 13 @ 2:23 am
I used the NI s4 case. works perfect, plus has space for mic,wires,extention cords. plus its cheap!
http://www.americanmusical.com/Item--i-NAT-20901-LIST
geposted Sun 17 Mar 13 @ 11:00 pm
That's no good for the Mixtrack Pro II. Remember the II version has the headphone and mic jacks on the right side.
DJJames
DJJames
geposted Sun 28 Apr 13 @ 9:58 pm
Get a decksaver and a backpack and call it a day.
http://www.americanmusical.com/Item--i-DEC-PCMIXTRACKPRO-LIST
geposted Mon 29 Apr 13 @ 1:31 pm
Simple google search and I came up with dozens.
https://www.google.com/#output=search&sclient=psy-ab&q=mixtrack+pro+case&oq=mixtrack+pro+case&gs_l=hp.3..0j0i22i30l3.1171.5216.0.5322.17.17.0.0.0.0.99.1294.17.17.0...0.0...1c.1.11.psy-ab.-eHSYWSqrkI&pbx=1&bav=on.2,or.r_cp.r_qf.&bvm=bv.45645796,d.aWM&fp=4fb34227f337626b&biw=1085&bih=703
geposted Mon 29 Apr 13 @ 1:35 pm
