Does anybody know why after recording a sample it seems much lower than the default samples? For instance, I recorded a siren sample of my own to add to my mixes but you can barely hear it over the songs compared to the default samples... Is this usual in virtualdj or is there something I can do to record them louder?
btw the volume is also turned all the way up for the sampler.
geposted Tue 22 Feb 11 @ 6:08 pm
Not sure if you have tried this but U can turn up the volume fader if you click on the samples tab. And if that doesn't work then U can always run them through an audio program and bring the loudness up some.
geposted Wed 23 Feb 11 @ 12:14 am
Its really weird, sometimes the sample even sounds more high pitch when its played over a song but when its played by itself it sounds normal. Don't know if this happens to anybody else or if this is just some weird bug on mine.....
geposted Wed 23 Feb 11 @ 3:16 am
