I've got 2 questions:
1: it seems like a few of my own made songs dont have the right bpm in VDJ, is there a way to edit the VDJ bpm of the song to the right bpm without changing the tempo?
2: is there a way to pitch more precisely?, because For example the bpm changes from 163 to 166 and i need something in between
geposted Wed 23 Feb 11 @ 12:32 pm
If your using the stock VDJ skin I believe you can right click where it says BPM. That should make a window pop up where you can edit your bpm. Well it change the tempo I don't think so as long as the changes aren't that serious. For the pitch are you using a controller or keyboard and mouse?
Hope that helps
Huey
Hope that helps
Huey
geposted Wed 23 Feb 11 @ 3:33 pm
yes it helped, thanks, it makes things a lot easier =),
i still use keyboard and mouse
geposted Wed 23 Feb 11 @ 4:10 pm
You can match BPMs down to a 0.001 BPM resolution IIRC.
geposted Wed 23 Feb 11 @ 4:18 pm
You can tap the BPM button of the appropriate deck on the default skin in time to the beat to manually set the BPM.
Or right-click on the button as above for more advanced editing options, along with options to adjust the CBG (Computer Beat Grid squares under the waveform.)
geposted Thu 24 Feb 11 @ 6:18 am
