Set Up
Macbook
VDJ 6 Pro
Herclues RMX
2 RCA leads to Mixer
2 CDJ-1000 input
Played a gig last Wednesday, everything was fine. Had a gig last night and the output from channel 3/4 was all fuzzy and wasn't a clear sound at all. Had to resort to play out of output 1/2 while using the RMX as a mixer, which was less than ideal.
Output from channel 3/4 was maxing out the mixer to red. Tried changing RCA's, didnt work. Plugging into a different input on the mixer, didnt work.
Any suggestions?
Gareth
Macbook
VDJ 6 Pro
Herclues RMX
2 CDJ-1000 input
Any suggestions?
Gareth
geposted Wed 23 Feb 11 @ 8:38 pm
Sounds like you might have switched it to phono instead of line maybe??
Huey
Huey
geposted Wed 23 Feb 11 @ 8:59 pm
Nope, I put it into various "line in" inputs on the mixer and gave the same result.
geposted Thu 24 Feb 11 @ 3:56 am
Just to be clear, you are using the Rmx in an External mixer configuration (each deck going to a different channel on the mixer) ?
Did you get a chance to verify if the signal coming out of the Rmx Headphone output and 1/4" Output 3/4 was also "fuzzy" ?
You obviously made sure that the output levels in VDJ were not peaking when the problem occured ?
geposted Thu 24 Feb 11 @ 6:26 am
