Crossfader, Gain, Treble, Mid, Bass is not working with VDJ7Pro. If I connect my Iphone and use the crossfader I can see it slide back N forth on the screen. If I use it on my mixdeck it doesn't do anything. Same goes for changing my gain, treble, mid and bass and both sides. It all works on the mixdeck but what I'm talking about is it actually moving on the screen. It doesn't show that I am turning those knobs are showing that I am sliding my crossfader. Is there anything on the mixdeck to turn the filter up and down? I haven't seen anything on there to mess with the filter. Same goes fr the keychanger. Pitch bend works and all and my bpm sliders both work on the screen. I can see them move no problem. Also my paramter works on the screen as well as my wet and dry. I can see all of that move just the ones I am talking about I can't see move. Any help on this would be greatly appreciated :D
geposted Thu 24 Feb 11 @ 4:48 pm
That's because the mixer section is not a "Midi" Mixer, in no way shape or form will it move things on your screen. Only the decks are Midi. As for the filter you'll have to map that yourself. What I did was map the wet/dry slider as my filter and use the start/stop knobs down below as my effect parameters 1 & 2. Then the knob the was effect slider 2 up top I switched that to my video crossfader. All works like a champ!! I could send you my mapper if you want. Just shoot me a pm.
Hope that helps
Huey
Hope that helps
Huey
geposted Thu 24 Feb 11 @ 11:49 pm
