Can you record sounds off your pc and use them on virtual dj like record things off your pc and put them straight onto the sample section.
geposted Thu 24 Feb 11 @ 7:02 pm
I think that if you click on the portion of the sampler you can point the sound you would like to play, allthough i am not sure.
You do not have a liscence if you are using home edition of VD7 i dont know if you can have diferent samples or just the stock ones.
Hope this helps!
Simon
Hope this helps!
Simon
geposted Thu 24 Feb 11 @ 7:49 pm
I believe you can sir. I will check and get back with you to be sure.
Andre
Andre
geposted Fri 25 Feb 11 @ 12:54 pm
Can you map a key to record a specific length of sample eg 4, 8, 16 bars, I have never really used the sample record because its too hard to start and stop the recording in the right place
geposted Fri 04 Mar 11 @ 11:39 pm
Yup that's how you do it. Make sure you have you cbg grid perfect though or else the sample will not record right.
Huey
Huey
geposted Fri 04 Mar 11 @ 11:43 pm
