hi
i've bought a pioneer 350 set (2x CDJ-350 1x DJM-350 yesterday and i wanted to connect it with virtual dj
i already instalt the midi channel to 1 and 2 in the CDJ's
both deck are working only my mixer doesnt work
both decks are going through ch-1 off my DJM
plss help me!!
plss help me!!
geposted Fri 25 Feb 11 @ 12:05 pm
You need the Pro version of the software.
Then you will make sure the CDJ drivers are properly loaded and use the following sound card options.
Inputs - None
Outputs - External Mixer (Left 1&2 / Right 3&4)
Soundcard - ASIO - selecting the Pioneer CDJ ASIO driver
But you must be using the Pro version.
Inputs - None
geposted Fri 25 Feb 11 @ 12:17 pm
well that worked for a while
but now i got a new problem
both decks (A, B) react on just deck A
but when I connect it to my laptop is works fine
pls help :D
pls help :D
geposted Sun 24 Apr 11 @ 7:44 am
