to all mac users this forum Can you tell me that mbp and vdj are working Perfect with no No issues ?
its just the high cpu when loading a song That worries me, 110%-120% on a new mbp 2.4ghz Does not sound good...
geposted Fri 25 Feb 11 @ 6:43 pm
High CPU is normal when loading a track - it's to get the track loaded as quickly as possible.
geposted Sat 26 Feb 11 @ 10:15 am
that's somewhat normal...... mine isn't that high though.
geposted Sat 26 Feb 11 @ 10:33 am
what about the small lag when loading a song ?
geposted Sat 26 Feb 11 @ 11:12 am
40%-50% its o.k but 100%+ deos not look normal...
geposted Sat 26 Feb 11 @ 11:18 am
100% or near is normal on a single core or slow processor.
Slow loading is also normal on a slow processor and/or slow external hard disk (5400 rpm)
Also, you may get slow loading if you are loading videos and have chosen Quality resampling for 48Hz Conversion.
geposted Sat 26 Feb 11 @ 1:27 pm
Why not?
The VDJ engine will regulate the loading speed so that the loading of a track doesn't impact audio and video output. Outside of that I want the track loaded as quickly as possible, so I'm happy for it to use a large amount of CPU power to get the job done as quickly as possible.
I'm unsure what you mean by 100%+ though - how do you use more than 100% of your CPU power? Unless you mean 100% of one core and a small percent of another - in which case you still have massive processing power available.
geposted Sat 26 Feb 11 @ 1:53 pm
my mbp is core 2 duo 2.4ghz the last model not single core...
sbdj on a mbp you can see on the process monitor more then 100% its gets even to 120% when loading a song
and what about the small lag when you load a song ? its dosn't seems normal on a strong laptop like MBP
geposted Sat 26 Feb 11 @ 7:07 pm
