When using automix and I try using karaoke files on the other deck it is syncing the karaoke file even though auto pitch match is turned off. In fact it sun s all files when turned off. Is there a solution to this
geposted Sat 26 Feb 11 @ 4:47 am
Make sure beat lock is off (If the SYNC button on the default skin is lit up solid, then it is on.)
Make sure smart play (The small pad lock icon above the PLAY button on the default skin) is also turned off.
Make sure CONFiG -> Options -> Auto Pitch Matching is off.
geposted Sat 26 Feb 11 @ 2:08 pm
I'm having this same issue and didn't realize this thread was active.
I've added a couple of tracks to my library and they are Pitch Matching off each other.
I can't figure out why and it's making me crazy.
Options seem correct for me...
Any additional thoughts?
geposted Tue 01 Mar 11 @ 7:22 pm
