Does any one know how to get back to the option of Master & Mic on the Broadcast Config menu? I selected master only and I want to go back and change this option but it does not seem to be there? I'm out of idea's... Thanks
geposted Sat 26 Feb 11 @ 5:02 pm
A previous version of Virtual DJ which I used had three options on the broadcast config setting for the source of your music. Master, master and mic and line in. The latest does not have any options.
Does anyone know how to alter this in the new version as I need to change the inputs from time to time.
geposted Tue 17 May 11 @ 1:23 am
You have to use the Record Loopback feature.
But before you have to connect your Output signal with a LineIn.
Then use the Advanced Config and setup additional, the Record Loopback.
Record Loopback - Your LineIn Soundcard - Input 1&2
Now the broadcast section grab this signal and stream it to the radio.
geposted Tue 17 May 11 @ 5:30 am
I don't really understand this last piece of advice. Sorry.
Where is the Advanced config I can't find it on Virtual DJ. Are you talking about my pc control panel?
My system involves using hercules mk 11 and an external mixer (allen and heat xone 62) with a connected mic. The signal from the external mixer is then fed into the laptop via the mic input.
I want to broadcast this input rather than the virtual dj sound output.
geposted Tue 17 May 11 @ 2:39 pm
