I can't seem to get the iRemote app for my ipod touch to find my laptop, they're both on the same wifi network, but neither wants to find the other, any suggestions?
geposted Sat 26 Feb 11 @ 5:16 pm
download "Bonjour Print Services" from apple.com or install the the latest iTunes
geposted Sat 26 Feb 11 @ 7:10 pm
Also, make sure that you have the latest v7.0.2 Home FREE installed: https://virtualdj.com/download/free.html
It will not work in earlier versions.
geposted Sun 27 Feb 11 @ 1:23 pm
Sorry to Hijack, but I am having the same issue. Funny thing is, I get get the iTunes remote to work just fine remotley, but can't seem to get it to work for VDJ. I have bonjour installed and the latest version of VDJ home. What am I doing wrong?
geposted Sun 27 Feb 11 @ 1:32 pm
did you authorize it with VDJ? in order to start using it you need to give the device permission to control VDJ
geposted Sun 27 Feb 11 @ 4:44 pm
Check also your firewall
geposted Mon 28 Feb 11 @ 5:27 am
need help!!!!my vdj app on my iphone cannot detect my pc
geposted Sat 03 Dec 11 @ 11:50 pm
Please see: https://virtualdj.com/wiki/iRemote.html
geposted Sun 04 Dec 11 @ 1:07 pm
i have done the step and it is going well my windows detects my iphone...THANKS!!!!.......BUT!!!i cannot play it... do i need to install the bonjour?...thank you
geposted Mon 05 Dec 11 @ 1:53 am
Yes, you need Bonjour installed because iRemote uses it for its communication.
You also need the latest version of VirtualDJ Home FREE installed: https://virtualdj.com/download/free.html
geposted Mon 05 Dec 11 @ 5:03 am
i already have the latest version of VDJ...and i am running a windows 7, i have downloaded the bonjour yet still it doesn't work i cannot still play it from iphone...thanks
geposted Tue 06 Dec 11 @ 12:49 am
one last thing just to make it clear for me...what if i dont have the wi-fi on my iphone does it still works?...
geposted Tue 06 Dec 11 @ 1:03 am
It won't work if you don't have Wi-Fi enabled. It requires a Wi-Fi connection between your phone and computer (That's the whole point of iRemote!)
If you don't have a wireless access point available, you can setup an Ad-Hoc Wi-Fi connection between your computer and phone. Instructions can be found on the page http://www.fromdjs4djs.com/virtual-dj-iremote
If your phone is not capable of Wi-Fi, then you will need to upgrade it.
geposted Tue 06 Dec 11 @ 5:12 am
Does Virtual DJ make a smart phone app for the new Windows phone operating system? I know they have it for iphone and ipad. Got a windows phone and am waiting on several apps to be developed. VDJ being one of the. Thanks
geposted Sat 14 Jul 12 @ 12:34 pm
No. iremote is supported on iOS only at present.
Keith
Keith
geposted Sat 14 Jul 12 @ 12:46 pm
