hi=)
just wondering..
how hard would it be to implement some sort of column for a value for what the camelot key would be after the tempo of the track is warped to the *master tempo?
basically, you wouldnt need to reanalyze the track for the key at the new tempo,- you would just have to take the pre analyzed key and subtract or add the bpm difference so it translates to the new key value...
anyway, just an idea :P
just wondering..
geposted Sat 26 Feb 11 @ 9:21 pm
so i'm the only one who thinks this would be another groundbreaking feature? :P
geposted Sun 27 Feb 11 @ 10:43 pm
That is a good idea, and one that I've wanted to see in software too.
The trouble is that VDJ is not very good at getting the key right in the first place!
Would be nice: Ability to show the correct key, change it when the pitch is changed, and even search for/display songs in compatible keys.
geposted Mon 28 Feb 11 @ 7:31 am
You can search/display songs in compatible keys - filter folder element 'keydiff' can do that.
Oddly enough I noticed and reported the key not updating as the pitch does this morning - it does however update if you activate keylock at the relevant pitch.
geposted Mon 28 Feb 11 @ 7:48 am
