Just curious on why do I have to setup my mixtrack pro as an advanced config in the sound options in order to get my outputs & my cue outputs to operate correctly? Am I doing something wrong is that just the way it is supposed to be?
geposted Mon 28 Feb 11 @ 1:40 am
You need to setup your CONFIG in VDJ for your output to be Master + Headphones. Master channels 1&2 and 3&4 are your headphones. From there make sure you have your CUE mix dial on the MT Pro turned up, and selected on either CUE or PGM. Private message me if you run into any more issues
geposted Sat 26 Mar 11 @ 3:56 pm
