ok so i know there is probably loads of threads about this but none match my needs.
I have some money left over from my birthday (£84) and i wanna get a little controller just for my bedroom and private events.
i have narrowed it down to two; the Hercules mp3 e2 and the Hercules mk4
so in other words shall i save up for the mk4 or get the mp3 e2 and just buy an external soundcard, cause it seems the mk4 is just a e2 with a soundcard and inputs i dont need.
please let me know ASAP :):):):)::::::::::::)_
geposted Mon 28 Feb 11 @ 3:08 pm
MK4
geposted Tue 01 Mar 11 @ 3:20 am
but, its like double the price when i could just get a cheap usb soundcard
geposted Sun 06 Mar 11 @ 11:37 am
Thats also true :-) you decide whats suits you best mate.
geposted Sun 06 Mar 11 @ 2:29 pm
"cheap usb soundcard"- only important word there is the "cheap" bit! It'll be rubbish for using DJ headphones with because it won't be that loud :( or very good quality.
Perhaps that might be a good temporary solution whilst you save up for a better sound card.
Hope that helps.
Hope that helps.
geposted Sun 06 Mar 11 @ 5:03 pm
Also, you might want to think about the e2, it's good, but very small. Check out this video
http://www.youtube.com/watch?v=N4MPO8ReFu0
And for £129 you could get the numark mixtrack which has touch sensitive jog wheels and it's bigger and so much easier to use. Check out this video
http://www.youtube.com/watch?v=oFEsITfqqF4
If you could save up £129 for that and your really cheap usb sound card, and then later you could save up for a good dj sound.
geposted Sun 06 Mar 11 @ 5:07 pm
I have been using the MP3e2 for a while now. It's a great little controller and has done it's job well, never had a issue with it at all. I use it with the NI Audio 2 DJ sound card. Great for beginning DJs or Experianced DJs switching over to PC DJing.
geposted Sun 06 Mar 11 @ 7:12 pm
