Hello!
I am working still with vdj5 , connected to an maudio fast track pro , and two channels of an allen n heath 42 analogue mixer
I am interesting in getting an allen n heath 2d sound card to use instead of the maudio and upgrading to vdj 7 pro
Is there any mapper of it or will i only use it as a sound card (asio driver) ??
Anyone made a mapper for it?
i wanna stop using my keyboard
Thank u
Thank u
geposted Mon 28 Feb 11 @ 6:28 pm
You can use the Xone:2D as both the sound card and controller. I have the Xone:1D which is basicly the same device without the sound card, so the mapping is more less identical. Here's my XML-data for reference. Send your e-mail address as private message and I'll send the mapper file to your e-mail.
Bear in mind that this mapping is made for my personal needs and made to be used in conjunction with my other controllers, so your preference might vary. However, it should give you a good start with your own mapper.
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI" author="Atomix Productions" description="Allen & Heath Xone:1D" version="702" date="27/12/2010" priority="-10">
<map value="MIDI_CLOCK" action="off" />
<map value="0-9" action="deck default seek +2000ms" />
<map value="0-11" action="deck default seek -2000ms" />
<map value="0-14" action="deck default effect active" />
<map value="0-15" action="browser_window "songs"" />
<map value="0-17" action="deck default seek -1" />
<map value="0-16" action="deck default sampler play_stop" />
<map value="0-18" action="deck default loop_half" />
<map value="0-19" action="deck default key_lock" />
<map value="0-20" action="deck default play_pause" />
<map value="0-21" action="deck default loop_out" />
<map value="0-22" action="deck default pitch_bend -2%" />
<map value="0-23" action="deck default masterdeck" />
<map value="0-24" action="browser_enter" />
<map value="0-26" action="video_fx" />
<map value="0-27" action="deck default seek +1" />
<map value="0-29" action="browser_folder" />
<map value="0-32" action="deck default loop_double" />
<map value="0-33" action="pitch_range "6,8,12,16,25" +1" />
<map value="0-34" action="deck default sync" />
<map value="0-36" action="deck default loop 4" />
<map value="0-37" action="deck default pitch_bend +2%" />
<map value="0-38" action="deck default hot_cue" />
<map value="0-CC8" action="deck default gain" />
<map value="0-CC9" action="deck default key" />
<map value="0-CC10" action="deck default effect slider 2" />
<map value="0-CC11" action="deck default effect slider 1" />
<map value="0-CC12" action="deck default filter" />
<map value="0-CC13" action="deck default sampler volume" />
<map value="0-CC15" action="video_fx_slider 1" />
<map value="0-CC16" action="deck 4 volume_slider" />
<map value="0-CC17" action="deck 3 volume_slider" />
<map value="0-CC18" action="deck 2 volume_slider" />
<map value="0-CC19" action="deck 1 volume_slider" />
<map value="0-CC33" action="param_greater 50% ? deck default effect select -1 : deck default effect select +1" />
<map value="0-CC34" action="deck default sampler select +1" />
<map value="0-CC35" action="param_greater 50% ? video_fx_select +1 : video_fx_select -1" />
<map value="0-CC36" action="param_greater 50% ? browser_scroll -1 : browser_scroll +1" />
<map value="0-CC37" action="param_greater 50% ? deck default jogwheel -0.1 : deck default jogwheel +0.1" />
</mapper>
geposted Wed 02 Mar 11 @ 4:07 am
