Forum: VirtualDJ Plugins
Topic: [NEW] [OTHER] WatchDog v1.0 Alpha - Page: 4
Would you be able to edit your plugin to carry out a long if/else statement such as:
songpos_remain 1% ? set 'WD_SongPos' 1 : songpos_remain 2% ? set 'WD_SongPos' 2 .... etc... etc
Then, I'll setup one LED with the vdjscript:
var_greater 'WD_SongPos' 50 ? on : off
I tested this out in VJDscript alone, but it will be a long messy script to manage :( I did get it to work though. When I load a song, I'll have it scan all the CUE points. At each CUE point, it queries the 'songpos_remain' and sets a variable.
I then have the LED check the variable that it meets a threshold, and it works. The problem is I have over 12 cue points, and it will be a scripting nightmare.
Thoughts?
geposted Tue 22 Nov 11 @ 10:41 am
Hey phantom,
I made a test to see what the best settings would be, that is repeated every 130ms, and 30 scenes, would it be pushing the friendship to ask for and increase in the amount of cyces to 40 for the load one and 80 for oninit?
geposted Wed 23 Nov 11 @ 12:19 pm
hey phantom sorry for hijacking... this is 81 scenes at 100ms
geposted Thu 24 Nov 11 @ 4:12 am
It seems that I should make the step length and duration user adjustable... :P
geposted Fri 25 Nov 11 @ 7:18 am
that would be all kinds of awesome! :)
geposted Fri 25 Nov 11 @ 7:40 am
Hi, PhantomDJ, I have watchog version 1.5 installed on my computer. I go the effects/others tab, and select timed out automix, and activate
Then I go to my music browser, and enable automixing, however nothing happens....I feel like I have tried everything, but it is still not working.
Help please
Thanks in advance
geposted Mon 13 Aug 12 @ 2:24 pm
What's your TimeOut Reading ?
geposted Mon 20 Aug 12 @ 2:33 pm
Updated to version 1.0.8
Besides the timed out automix, Watchdog currently provides the following functions:
  • Last Used Hot Cue: Plug-in sets variable 'WD_LUC' (deck specific)
  • Original Key: Plug-in sets variable 'WD_ORKEY' (deck specific)
  • Load file from browser and copy loaded file to Sidelist: user must set variable 'WD_LC_SL' to 1 on the desired deck
  • Load file from browser and copy loaded file to Playlist: user must set variable 'WD_LC_PL' to 1 on the desired deck
  • Check BPM Sync between Left & Right decks: Plug-in sets variable '$WD_BPMLR_SYNC' (Global Variable)
  • Check BPM Sync of each deck versus Master deck: Plug-in sets variable 'WD_BPMMAS'(deck specific)
  • BrowserSortMode: Plug-in sets variable '$WD_BRSM' (Global Variable)
  • Start playing on next PRIMARY beat (works with Left/Right deck logic): user must set variable 'PLAYONPRIMARYBEAT' to 1 on the desired deck
  • HotCue Position: Plug-in sets variable 'WD_HCPOS' (deck specific)
  • Cycle A: Plug-in cycles variable '$WD_CYCA' (Global Variable)
  • Cycle B: Plug-in cycles variable '$WD_CYCB' (Global Variable)
  • Cycle C: Plug-in cycles variable '$WD_CYCC' (Global Variable
geposted Fri 15 Mar 13 @ 4:33 am
As of today, this plug-in should be considered as deprecated.
A new improved plug-in will be available soon.
Thanks!
Topic Locked!
geposted Wed 20 Mar 13 @ 8:37 am
