Hi Sir
I am Looking to Hook Up NUMARK CDN 95 with timecode cds with VDJ Windows 7 and BX14 rodec.
Are they Compaitiable with each other CDN 95 and VDJ?
How do I set them up can you please help..
Which sound card is better Maya or Gigport HD?
Kind Regards
H
Kind Regards
H
geposted Tue 01 Mar 11 @ 4:55 am
Any standard DJ CD player can be used with VirtualDJ by using timecode CD's.
You will need a suitable ASIO sound card with 4 inputs and 4 outputs such as Hercules DJ Trim, Native Instruments Audio 4 DJ or ESI Maya44 USB.
NOTE: Gigaport HD is not suitable because it has no inputs for the timecode signal. It has outputs only.
Timecode CD's can be created yourself using the file downloadable from http://www.virtualdj.com/products/timecode/cd.html - Simply use your CD writing software to burn a couple of audio CD's using this file.
VirtualDJ Professional http://www.virtualdj.com/buy/index.html is required for timecode use (VirtualDJ Home FREE allows timecode to be tried out for 10 minutes at a time: http://www.virtualdj.com/download/free.html )
NOTE: Your computer needs to meet and preferably exceed the recommended specification on the following page: http://www.virtualdj.com/products/virtualdj/index.html
geposted Tue 01 Mar 11 @ 12:20 pm
Hi mate.
Be aware that some of the CDN95 effects might behave diferently to what you expect when using timecode. If you like the CDN95 another suggestion for you would be to pick up a DMC2 controller. Its front panel layout matches the CDN 95. Although Numark no longer make the DMC2 there are still plenty of them about and you should be able to get one fairly cheeply.
Daz
Daz
geposted Sun 06 Mar 11 @ 3:49 am
Thank you Very Much for your input Really Appericiate.. Now I will lokk in to both and see which one is better suited to my needs..
Kind regards
H
Kind regards
H
geposted Tue 08 Mar 11 @ 1:16 pm
hi all.
i have a Numark CDN 95. and my sound card is Scarlett 2i2.
can i use virtual dj ?
geposted Thu 26 Dec 13 @ 1:11 am
Hi mate
The Focusrite 2i2 has only 2 Mono channels, 1 Left and 1 Right. For timecode use you need a card which has 4 input channels and 4 output channels. This gives you a Left and Right Channel for each deck.
There are plenty around though ( Hercules DeeJay Trim for example) and yes you could use the CDN95 with them.
Cheers
Daz
Cheers
Daz
geposted Sat 28 Dec 13 @ 1:56 pm
