Say I have a track playing on deck 1. I search for my next track and instead of loading it onto deck 2, I accidentally press the deck 1 load button. Is there a setting that will not allow the loading of a deck while it it playing?
Thanks,
mike
Thanks,
mike
geposted Tue 01 Mar 11 @ 12:29 pm
yes go to options and put security always on mate
geposted Tue 01 Mar 11 @ 1:01 pm
Hi I wanted to Know How To add Multiple hot cues or cue points. I'm pretty good with the computer but need guidance step by step.
Thanks.
JT
Thanks.
JT
geposted Tue 01 Mar 11 @ 1:06 pm
The answer is waiting for you in the previous thread you posted....
geposted Tue 01 Mar 11 @ 1:37 pm
