Hiya im about to purchase a denon 6000 here in the uk. However uk versions come with traktor and not virtual DJ (which i find much better to use).
If i do purchase in the UK, is there any way i can get virtual DJ LE installed or am i gonna have to buy from the USA to get it?
Many thanks
Rich
Many thanks
Rich
geposted Tue 01 Mar 11 @ 3:39 pm
VDJ LE only comes with the US units, however beware if you go down that route as VAT, duty & courier charges will mount up. Also the warranty on US units isn't valid in the UK so you'll have the expense of sending it back to the US if anything goes wrong.
Only benefit of the US route is that you will get a discount on purchasing VDJ Pro with the LE serial number.
I just bought in the UK but then I had VDJ Pro anyway .....
Keith
Keith
geposted Tue 01 Mar 11 @ 3:58 pm
Ok thanks keith
geposted Tue 01 Mar 11 @ 4:32 pm
