Hey, I think the most recent Hercules RMX driver is causing issues with my VDJ setup. I removed the app and am trying to install a previous driver but it keeps saying it cannot install on the current disk because a more recent version is already installed. Can anyone help me get rid of this so I can install this old driver
geposted Tue 01 Mar 11 @ 8:56 pm
All you need to do is to delete the entire Hercules folder in Application.
What type of problems are you noticing ?
geposted Wed 02 Mar 11 @ 6:10 am
Hey I tried that but it didnt work. But here is my problem. I run VDJ with Hercules as the soundcard. After about 20 minutes or so the songs will start to clip, and eventually the sound will go out. I hear nothing through headphones or speakers. And also VDJ will stop responding to the play button on my hercules, so if i try to play a song it does nothing, it still will recognize the volume buttons if i mess with the crossfader or volume on the Herc i see it change in VDJ, but if I Push PLAY in VDJ without using the Controller NOTHING happnens, If i change the output in VDJ to Built in speakers everything starts working again. I have all the latest drivers and firmware for the Herc and the most recent Virtual DJ i even tried going back to a previous version of VDJ and it still had the same problem
geposted Thu 03 Mar 11 @ 1:52 pm
