Hi everyone.
I have noticed that everytime that I run Virtual DJ that the master knob on the skin always goes to max, why does it do this and would this be the reason why it would distort when playing through denon hc4500 as before I did not notice this happening.
geposted Wed 02 Mar 11 @ 5:47 am
Master volume always defaults to 100%, but this shouldn't in most cases cause any problems.
Perhaps the software gain of a song has been set too high?
Or there are issues with sound driver? (Try using a slightly higher latency setting and/or update the drivers/firmware from http://www.denondj.com if you do not have the latest installed.)
NOTE: If you wish to set a different master volume setting, you could map ONINIT action for the HC4500 to do this. Map it to the action: master_volume 75% (Ot another value of your choice.) This will then set the master volume to this value every time you start VirtualDJ with the HC4500 connected.
geposted Wed 02 Mar 11 @ 11:38 am
Hi Guys,
I'm really really stuck. I'm using vdj pro 7 and i need to broadcast to an icecast stream. I'm adding /live at the end of ip and I am able to connect to the icecast stream.
I cut into the auto stream but the music wont play in the stream.
Please please help if you can! Am I missing something?
Thanks,
Georgi
Thanks,
Georgi
geposted Fri 04 Mar 11 @ 11:05 am
