Hello,
Question #1
for starts - is their a MIDI Controller that will work with 2 turntables w/ timecoded vinyls
if so anything under $150-220 ~ or if its just a little over, and a lot better, that works too...
---PREFERABLY ONE WITH 4 CHANNELS---
Question #2
I have a ASIO (Maya44), I was wondering...
Is it possible to use my turntables w/ virtual dj, with serato timecodes, with my soundcard and no mixer?
if so that would be great too..
Question #3
What is a good Mixer, that I can use my turntables with virtual dj...
---PREFERABLY ONE WITH 2 CHANNELS---
--------AND GOOD FOR SCRATCHING--------
Reason: A while ago, I bought a Maya44, 2 Numark TTUSBs -beltdrive- (YES I KNOW THEY SUCK), and a Numark M1 USB, 2 Serato Vinyls...
I am on a TIGHT, TIGHT, TIGHT BUDGET
I didn't educate myself in DJ hardware at that time, and blew a lot of money, and was mad...
Now I need something that will work, something that will be DECENT, or even semi-bad, I don't really care
Just need help...
-SUBSCRIBE PLEASE-
-DJ Delete (http://www.youtube.com/user/ElementCZ12345745)
Question #1
Question #2
Question #3
Just need help...
-SUBSCRIBE PLEASE-
geposted Wed 02 Mar 11 @ 7:49 pm
Ok to answer all your questions in one shoot, I'd say buy a Hercules RMX. it's a midi controller slash mixer. It can be used with or without turntables has it's own built in soundcard and only cost around 350 US dollars plus it comes with VDJ LE and after you register it you can get a nice discount on the PRO version of VDJ.
As far your setup goes now you already have the tables, not the best but they'll work, you have a Maya 44 which is a nice soundcard so really all you need is a cheap 2 channel mixer and you'll be good to go.
But if it was me I'd sell it all and just buy the Hercules and call it good!
Hope that helps
Huey
Hope that helps
Huey
geposted Wed 02 Mar 11 @ 10:36 pm
Wow, Thank You...
Specifically, what mixer would be good?
geposted Wed 02 Mar 11 @ 10:55 pm
http://www.google.com/products/catalog?hl=en&rlz=1G1GGLQ_ENUS306&q=dj+mixer&um=1&ie=UTF-8&cid=843313678664084379&sa=X&ei=0itvTZbEMoyssAO2rLS-Cw&ved=0CGEQ8gIwAw#
j/w would ^that^ work with my set up? (maya 44 + turntables)
geposted Thu 03 Mar 11 @ 4:14 pm
Yeah I don't see any reason why it wouldn't. But do you really need 5 channels? Look up the VMX-300. I have one and its my back up. Its a 3 channel mixer and its a 10 inch.
Good luck and hope to see you as a pro user soon ;-)
Huey
Huey
geposted Fri 04 Mar 11 @ 11:07 am
that is an awesome alternative, one question i looked at some vids on youtube of this, do the effects work well?
geposted Sat 05 Mar 11 @ 8:29 pm
Umm what effects are you talking about? The mixer doesnt have any effects. Heres a pic,
If your talking about the back where it says effects that for running an outside source that will apply it to your tracks, but thats another topic. I would say for the money this is a great mixer for someone just starting out.
Huey
Huey
geposted Sun 06 Mar 11 @ 9:38 am
thanks thats what im going with :D
geposted Sun 06 Mar 11 @ 2:32 pm
Now all you gotta do is save up and buy VDJ PRO ;-)
Glad I could help bro
Huey
Huey
geposted Sun 06 Mar 11 @ 2:43 pm
Hi can someone tell me if i can conect 2 or 3 diferent controlers for virtual dj??
geposted Wed 09 Mar 11 @ 7:18 pm
Its best to start your own thread a.d the search does work but to answer your question, yes you can.
Good Day
Huey
Good Day
Huey
geposted Wed 09 Mar 11 @ 8:03 pm
