Is there a way for me to start the next song in the Automix playlist without having to ddouble click on it? I currently use VDJ 7 with a Hercules RMX.
geposted Fri 04 Mar 11 @ 3:16 pm
are you using automix or just the automix window for quick load>
geposted Fri 04 Mar 11 @ 5:11 pm
create a keyboard shortcut with the following action..
automix_skip
automix_skip
geposted Fri 04 Mar 11 @ 6:57 pm
Got it! Thanks!
geposted Mon 07 Mar 11 @ 10:17 am
hello,
i have not been here in a white I would like to know why automix cannot be use on VDJ LE
geposted Mon 07 Mar 11 @ 3:03 pm
Sorry, VirtualDJ LE is free limited software and does not support playlists and automix. Please see https://virtualdj.com/products/comparison.html
To be able to do this and much, much more, you will need to upgrade to the full VirtualDJ Professional at a discount: https://virtualdj.com/buy/
geposted Tue 08 Mar 11 @ 5:51 am
