Hi. I figured this would be something pretty simple to do, but I just can't figure it out. I'm on an Akai MPK Mini using VDJ6 and I'd like to set one of the pads to switch the active deck. So far, I have this as the action:
action_deck 1 ? deck 2 select : deck 1 select
It works if I have my pad set to 'toggle' (in Akai's software), but not if the pad is set to 'momentary'. This is the case with anything I try to do with the pads. For example, if I set one of the pads to pause, it will only pause for as long as I hold it down, unless I change the pad setting to 'toggle'.
Is there any way I can make the pad toggle between the two decks while keeping the pad set to 'momentary'?
geposted Sat 05 Mar 11 @ 4:48 am
Anyone?
geposted Mon 07 Mar 11 @ 7:14 pm
Is there an option from Akai to make a certain pad as toggle and several other as momentary? I'm afraid that the above code will work only in toggle mode.
In my opinion you should choose the toggle mode, and in case you need some momentary actions like trigger sampler as the button is held down, you should use VDJ script actions like
sampler 1 play_stop while_pressed
geposted Tue 08 Mar 11 @ 3:55 am
Thanks. Yeah, there are individual options for pads. However, it's only for the pads themselves and not CC numbers.
geposted Tue 08 Mar 11 @ 5:44 pm
