thanks for viewing...cant seem to get my mic to work via the RMX...someone mentioned the advanced config option in the sound setup but i dont have that option a (+) sign...? i have 7.02 loaded...all updates...connecting through 1/4" obviously...tried 2 different mics to make sure it wasnt the mic...?
geposted Sat 05 Mar 11 @ 5:05 pm
...also trying to access my RMX settings tab and it is no longer in my tray...tried to access it through program files but it only shows an update access link...any ideas how to access the RMX settings...?
geposted Sat 05 Mar 11 @ 5:24 pm
r u clocking the mic button right next to the input?
geposted Sat 05 Mar 11 @ 5:32 pm
yeah im putting mic as input in the config...pushing the button on the RMX and checking the volume and making sure the button is highlighted and volume up in VDJ...obviously using the RMX soundcard...it has to be a simple dropdown somewhere i just cant navigate without a pathfinder...
geposted Sat 05 Mar 11 @ 5:38 pm
and the mic is good?
geposted Sat 05 Mar 11 @ 5:39 pm
...and ive been tryin to do this for so long my curls are getting rusty...
geposted Sat 05 Mar 11 @ 5:41 pm
mic is disco
geposted Sat 05 Mar 11 @ 5:43 pm
geposted Sat 05 Mar 11 @ 5:44 pm
...in addition i cant get my m-audio transit to play nice with VDJ when i try to use the mic that way...not enough channels...? thought it was the skin so i swapped from four to two decks...nada...went into the m-audio tray icon and no option for number of channels...
geposted Sat 05 Mar 11 @ 5:49 pm
thanks man...i think i need to get into the RMX settings but the icon is gone from my tray...gonna hitup the website...thanks again...
geposted Sat 05 Mar 11 @ 6:05 pm
hope things work out.
geposted Sat 05 Mar 11 @ 6:24 pm
...alright thanks guys...this is what is happening (and I am probably doing something very stupid):
Vista 64sp2
VDJ 7.02
RMX Driver 4 Package Installed
Windows Sound:
Playback: RMX working,
Recording: Line RMX working (other option is realtek mic which is working at the same time according to the volume meter but the volume meter next to the Line RMX shows nothing...obviously because I don't have a Line plugged in, I have a mic...?
VDJ:
Input: Microphone (As soon as I select this I get an error message about the ASIO driver that it is not connected or configured properly)
Output: Headphones (Master 1&2)
Sound Card: RMX (not RMX ASIO)
Broadcast: No option for Master + Mic
Autostart: Off
Format: MPEG with encoder
Server: Own puter
RMX:
Input: Mic 1-2
Advanced: USB Streaming 1-2 + Mic
Audio Mode: WDM (When I try to switch to ASIO and start VDJ it switches from ASIO to WDM)
Vista 64sp2
VDJ 7.02
Windows Sound:
VDJ:
Autostart: Off
Server: Own puter
RMX:
Input: Mic 1-2
geposted Sat 05 Mar 11 @ 7:38 pm
so it works now?
geposted Sun 06 Mar 11 @ 3:35 pm
...negative...even when i have the WDM option checked in the RMX settings...when i select microphone as input in VDJ the ASIO message comes up...arrrgggghhhhh.......
what does work is my M-Audio Transit sound card with a Headset Mic and Audacity....but that mic is garbage...looking forward to being able to use my sennheiser mic and VDJ...eventually broadcasting...can't figure out what i'm doing wrong....
geposted Sun 06 Mar 11 @ 4:47 pm
...also...i get the ASIO error message when i boot VDJ even though the inputs are set at Line-ins...so i get the error message when I boot...and i get it again when i change input from Line to Mic...
geposted Sun 06 Mar 11 @ 4:57 pm
VDJ need to be in ASIO in order to use the soundcard's input, be it for timecode or microphone.
Before anything, be sure to select Microphone for Input 1/2 in the DJ control panel.
Use the following configuration:
- Input : Microphone
- Output(s): Headphone
-Soundcard: DJ Console Rmx > check the box APPLY EQ ON INPUT ( which will switch the Rmx in ASIO)
Close VDJ. It should switch the control panel to WDM.
Launch VDJ, it shouold switch to ASIO automatically, and allow you to use the microphone by simply pressing the MIC button, and the signal can be recorded (you don<t need to select Master + Mic anymore).
geposted Mon 07 Mar 11 @ 6:47 am
DUDE, You're the man, because I went through the whole Hercules site and you know your stuff and the tips you gave me always worked. Now I never do a gig with the energy saver on and my Mac & rmx works flawlessly anywhere anytime!
Appreciate your great tips!!!
DJ COACH K aka THE MIX MONSTER
geposted Mon 07 Mar 11 @ 5:03 pm
...cool...thanks guys...gonna head home and try it out right now! :)
geposted Wed 09 Mar 11 @ 2:25 am
...wtf....? ok first things first--when i go to the config panel in VDJ and select Rmx as the soundcard it will not allow me to check the apply EQ box--its a ghost box...second--when i select mic as the input in the Rmx control panel it switches to line in when i open VDJ...third--when i try to apply the Rmx as the soundcard in VDJ i get the ASIO error message..........this is SO frustrating...any help is appreciated...
geposted Thu 10 Mar 11 @ 5:48 am
You might want to delete, and re-install the RMX drivers. Also, what OS are you running? Vista/XP/W7?
geposted Thu 10 Mar 11 @ 6:48 am
