sup all.. recently bought a numark mixdeck to mess around with, it came with the virtualdj software.. updated to the pro trial version so i could check that out... i've been messin around with diff connections and sound settings the past few weeks, but can't figure out how to be able to monitor a song in headphones... i got it to work with only the virtualdj software, but once i try to hook up to the mixdeck im totally lost.. i've been searching on here and reading a lot of articles and watching youtube but i cant seem to find the setup.. i bought the djio because i thought that would solve the problem but no luck... im pretty sure im just not understanding the connection process... if anyone could guide me to a link that could set me up or has the answer it would be much appreciated! thanks a ton.
andrew
andrew
geposted Sat 05 Mar 11 @ 5:59 pm
In sound setup make sure its set like this,
INPUTS=NONE
OUTPUTS=EXTURNAL MIXER (Deck 1 Chan1/2 Deck 2 Chan 3/4
SOUNDCARD=ASIO (MixDeck ASIO Driver, Ultra Latency-ASIO CHECKED
And you should be good to go
Holla if you need more help
Huey
INPUTS=NONE
Huey
geposted Sat 05 Mar 11 @ 7:24 pm
