Hello all. I am a recent buyer of Virtual DJ PRO and I uninstalled the demo, removed vdj files, and started from scratch with my full version install.
I am using 2 CDJ-400's and a DJM-400. For the last couple weeks I have been running the demo with the cdj's just fine.
I have selected them as my sound cards, however my right deck is deck 1, and my left deck is deck 2!
So when I load a song on the left deck, it loads on my right cdj.
Now, I would think you simply change the option for the 'Output Deck' in the config, but when I switch those... NO CHANGE.... the decks remain on the same right/left sides. I have tried restarting the program after saving settings as well.
I also understand that if I switch the USB ports, then it should work out, but the lengths of USB cable are setup right, so I do not want to physically change anything.
Basically I just want to swap decks! What am I doing wrong?!
Thanks.
Thanks.
geposted Sun 06 Mar 11 @ 7:57 pm
I figured it out for anyone looking for the same answer...
Go to Mappers section of config, then find the "Mappers Options" button... from here you can assign each deck :)
geposted Sun 06 Mar 11 @ 8:45 pm
Next time just press the 'Eject' button.
geposted Mon 07 Mar 11 @ 11:06 pm
