Here is a new update for VirtualDJ.
This update mainly adds controllers to the native list.
You can find the changelog in the wiki.
We also used this opportunity to change the installer technology used by VirtualDJ.
On PC, it now uses Windows-compliant .msi installer files.
On Mac, it now uses AppStore-compliant single-files .pkg
But the change in installer technology means that this new version will install new icons (on PC) or application (on Mac).
You can safely delete the old ones from v7.0.2 or before.
As usual, the update is free for licensed users, just get it from your Download Center.
geposted Mon 07 Mar 11 @ 1:27 pm
Nice. So what does the verb "Repeat" do? Tried checking it out on the verbs definitions on the wiki page but its not listed there yet.
Glad to see the bitrate and playlist issues are resolved for mac users. Thanks VDJ Team!
geposted Mon 07 Mar 11 @ 1:46 pm
Has this addressed the sound Advanced Config issue whereby you can't use multiple AISO devices?
geposted Mon 07 Mar 11 @ 2:03 pm
Not in this release unfortunately. It's not a quick fix as there are different Asio frequencies (44.1 & 48Khz) and they currently won't work together hence the reason that advanced config is still WDM only.
Keith
geposted Mon 07 Mar 11 @ 2:13 pm
It allows a button on a MIDI controller to repeat its action when held down, e.g:
repeat 100ms 500ms & browser_scroll +1
repeat 100ms 500ms & effect slider 1 +1
etc.
The Wiki will be updated soon, but context sensitive help is available for new actions in VirtualDJ's CONFIG -> Mappers.
geposted Mon 07 Mar 11 @ 2:30 pm
As always, thanks for the update.
-David
DJ Kavika
-David
DJ Kavika
geposted Mon 07 Mar 11 @ 3:02 pm
HELLO
I have a problems with my VMS4
the new version download Virtual dj 7.0.3
The LOOP in, out, beloop, loop does not work on VMS4
Do you have too a problem too ?
geposted Mon 07 Mar 11 @ 3:06 pm
In case you use a modified mapper or definition, please make sure that those xml files are still in theire positions (VirtualDJ/Mappers & VirtualDJ/Devices)
geposted Mon 07 Mar 11 @ 3:59 pm
Thanks for the 7.0.3 update!
geposted Mon 07 Mar 11 @ 4:18 pm
thank you
Dj Dad
it works
I'm so happy
Dj Dad
it works
I'm so happy
geposted Mon 07 Mar 11 @ 4:35 pm
Thanks team for all your hard work and VDJ for the free update! :-)
geposted Mon 07 Mar 11 @ 4:55 pm
You might want to quantify that since advanced config is most definitely not WDM only and you can indeed use multiple ASIO devices...
geposted Mon 07 Mar 11 @ 5:11 pm
Under native controllers it has the Gemini CDMP-7000. I can't even find any info for this controller on their website, is there any information that you guys can provide us?
geposted Mon 07 Mar 11 @ 6:41 pm
do you have to uninstall 7..0.2 and then install 7.0.3?
geposted Mon 07 Mar 11 @ 6:57 pm
I'm with Jim, any info on this mystery unit would be wonderful!!
Keep up the great work!
Huey
Huey
nice work team!
Nothing mystery about it...
http://www.dv247.com/dj-equipment/gemini-cdmp-7000--82879
geposted Mon 07 Mar 11 @ 7:26 pm
Quote :
fixed compatibility with 48Khz-only ASIO drivers
does this fix the sound drop-outs on AudioDJ 2 Usb cards??
Will test this later in the day..
geposted Mon 07 Mar 11 @ 7:28 pm
SBDJ wrote :
Well it is sad that they don't have it on the website, can't give any info on their facebook page and there is maybe 1 video I have seen of it so far. It is exactly what I am looking for as long as it is built well.
geposted Mon 07 Mar 11 @ 7:40 pm
What gives the file msi as opposed to exe ? also what the Difference in mac ? and Thanks for the update !
geposted Mon 07 Mar 11 @ 8:59 pm
