I want to buy a pioneer in the console, but it does not work VDJ. Which is better either VDJ or Serato for video mixing?
geposted Tue 08 Mar 11 @ 12:37 pm
IT ALL DEPENDS WHAT KIND OF EVENT YOUR DOING..IM USING BOTH WITH THE DENON DN-HC4500. AND THE SPACE U HAVE FOR EQUIPMENT
geposted Wed 09 Mar 11 @ 9:57 am
I wanted to know, if VDj will be working with Pioneer DDJ controller?
geposted Wed 09 Mar 11 @ 10:42 am
VDJ is more flexible and buggy, but it cost less. Serato just work. Mac user will choose Serato. It have all video/audio effects and work fine from box.
geposted Sun 13 Mar 11 @ 5:36 am
If you're video mixing with the Pioneer DDJ-S1 then you can't use Itch because it doesn't support video at present.
The DDJ-S1 is not officially supported on ScratchLive.
geposted Wed 01 Jun 11 @ 3:54 pm
