I am having a issue setting up the SL3 for CD Time-code use. It would be greatly appreciated if someone can help..
What makes the SL1 and the SL3 different is the SL1 has its own inputs and outputs for the THRU; but with the SL3 the THRU and LINE are coming out of the same inputs and outputs..
Within the Serato software they have a button next to each virtual deck that says TRU; When that is highlighted it plays whats in the CD deck of the CDJ, when that is not highlighted it plays whats on the virtual deck in the serato software..
Therefore when its being used with Virtual DJ it does control and plays the virtual deck in the software; but its not bypassing the THRU function on the SL3 so therefore its playing the time code-cd that's in the CDJ deck..
Now the big question is how to bypass the THRU function within the Virtual DJ software?
geposted Wed 09 Mar 11 @ 11:52 am
Have you mapped a button to "deck 1 timecode_bypass"? If I remember right it does work. I'm not at home but ill check it out and hit you up here.
Huey
Huey
geposted Wed 09 Mar 11 @ 3:15 pm
geposted Wed 09 Mar 11 @ 5:33 pm
Have you figured it out?
geposted Tue 15 Mar 11 @ 3:21 pm
